Old 03-31-2015, 08:02 AM
SS5150's Avatar
SS5150 SS5150 is offline
Default 1861 engine coupler
Hey all I want to pull the mag 18 from my 1861 to give it a much needed bath, I see a cv at the back of the engine with 4 Allen screws, do I remove those to separate it? I'd like to get going on it soon, going to need it to mow here shortly. Thanks
RUN IN THE RED
1872 project
Cub Cadet Pro Z 560 L
Old 03-31-2015, 08:12 AM
Sam Mac Sam Mac is online now
The shaft should just slip out of the CV joint at the engine end, it has a snap ring on the tranny end. Once you get it out it would be a good idea to disassemble it and clean the old hardened grease out and put some new grease in it. Drive shaft should have grease fittings on each end.
Old 03-31-2015, 01:12 PM
SS5150's Avatar
Thanks Sam I saw the fitting but couldn't tell how it separated. It must be splined inside the coupler then? I noticed the boot was not a tight fit to the shaft but there wasn't any kind of fastener there for it either.
RUN IN THE RED
1872 project
Old 03-31-2015, 03:32 PM
If the boot isn't torn put a zip tie on it when you put it back together.
Old 03-31-2015, 06:18 PM
Yep! Just did one today!
