Old 04-11-2010, 10:46 AM
Rhoderman's Avatar
Rhoderman Rhoderman is offline
Default Near Failure - Driveshaft Bolt
I'm pretty sure this should have been a spirol pin, but it was a Gr.5 bolt instead. I don't know how long it was in there for sure since this is off my donor 126. This shaft had a lot of wobble when I watched it through the holes in the frame. I hope it's just the coupler that is wallowed, and the input shaft of the tranny isn't too bad.
Jim in Lafayette, CO
Cub Cadet 122, 126
Old 04-12-2010, 07:56 AM
Jim:
IIRC, I think that should be a solid metal dowel pin in the drive shaft.
Maybe some of the Gear Drive guys can chime in on this.
Old 04-12-2010, 08:05 AM
Nope, spirol pin, just like the hydros.
Old 04-12-2010, 10:05 AM
murphycc
Guest
Posts: n/a
I've had two tractors with the steering columns destroyed because someone let the drive shaft go. One was a PS unit.
Scott
Old 04-13-2010, 11:45 PM
gravest's Avatar
gravest gravest is offline
My 122 has no choice but to use a grade 8 bolt to hold the drive shaft coupler together. It will not hold using a spiral pin. Suppose she's a little worn, but that was what held it together when I bought it.
If one cub cadet is good, Two or more would be heaven.
Old 04-14-2010, 07:59 AM
Not hold because they fall out, or because they break? If it's falling out, you need to safety wire it so it can't. A grade 8 bolt is going to destroy the coupler and input shaft on the trans.
