Can buy this for $400, but don't know much about this model. It's got a 16hp v twin and hydrostatic deck and transmission.
To me, if the mower deck wasn't rusted out and no weird noises from the deck bearings, if the tires were in good shape; the transmission works, ie it goes forward and back without a problem, noises or funny smells; and the engine runs and doesn't blow lots of smoke (burning oil) I would readily pay $400.
I then would put another $150 into it and lube all the grease fittings, change the HyTran and filter, change engine oil and filter if it has one, air and gas filter, and spark plug. |
The tractor was repowered with a different engine.... so the engine is not an original. Originally a single cylinder K341AQS Kohler. If originality of the 1650 isn't a serious issue for you, then at least consider the workmanship quality as far as the tractor had been modified for a different motor.
Two 125's and a 124 all with 42" decks Plow blade #2 Cart QA36 snowthower |
I wasn't sure of that engine either. Anyway, Hy-Tran isn't cheap if you buy it by the quart. I think it was $8/qt last time I checked and you need 7 quarts. CaseIH dealers sell it by the 5 gallon pails for a lot less per quart, which makes sense if you have a few Cub Cadets.
X2. Just my 2 cents.
if the engine runs good and don't smoke it's worth $300 or more alone
