Old 06-04-2015, 11:21 PM
clay1811/44c's Avatar
clay1811/44c clay1811/44c is offline
Default Ammeter connection fix maybe.
One problem I've had with my 1811 is the connection comes loose on the ammeter. So I decided to put two layers of shrink tube on it and see if that helps.
Old 06-05-2015, 05:34 AM
I'd cut that end off, put a traditional "eyelet or ring" crimp connector, and tighten it down with a "nylock" nut. Then you will know, it will positively handle the 15 Amp load.
