Old 04-19-2010, 12:03 AM
krisb krisb is offline
Default Problem with brake safety switch on 1811.
I recently started to have a problem with my 1811. If I depress the brake all the way down to start the tractor, the safety switch acts like it is still up and wont let the starter kick on. If I depress the break but hold about a inch up, it functions normally. I havent had the time to try and figure it out yet, but I figured I would run it by you guys for opinions.
Old 04-19-2010, 01:15 AM
murphycc
Guest
Posts: n/a
Switch is bad, replace or do as you are doing and not worry about it till it won't do what it's doing anymore.
Scott
Old 04-19-2010, 07:52 AM
squatch squatch is offline
If it's like my super there is a thin metal flat spring that pushes on the switch when you step on the pedal. it's held in with kind pd a tap nut over a roll pin. This may also be the culprit. Mine is cracked at the roll pin and will have to be replaced.
