Will a 451 blower fit and run properly on a 2284 . My attachment guide says it will? Thanks much
You should have the model 529 lift kit to maintain proper geometry due to the super being higher.
Are they still available, New or good used?
They are NLA.Some guys just make the brackets.
This post probably should be in the implement section. That said the extension brackets are NLA but are being reproduced by xtrememotorworks. See the link below, the extension brackets you will need are part way down the page. Other than the brackets you need a longer belt and maybe the lift bracket arm also made by extreme depending on the serial number of your tractor. I used these brackets from xtreme and I can say the fit correctly and are every bit as good as the ones from Cub Cadet. The lift arm bracket from xtreme is much stronger than the original cast one from the factory.
http://www.xtrememotorworks.com/Part...w%20Blower.htm
2082 w/60" Haban Deck & 450 Blower,AGs,weights 2084 w/54" Deck & 451 Blower 2086 w/54" Deck, 54" Haban Snow Blade 1864 w/54" Deck and weights 1641 w/48" Deck 1650 w/44" Deck parts Tractor (getting smaller all the time) 445 John Deere w/ model 40 FEL (went over to the dark side) |
thank you ...thought it would fit
