Z-Force S 54 with a manufactured deck. Used to use the deck wash system. Water and grass and mechanical things should never be mixed in my opinion. Not sure if it's my type of grass or what but I have to scrape the deck every 2-3 times I mow or its plugged and won't discharge. It will carry the grass under the deck choking and spitting chunks and wads out occasionally leaving a mess on the lawn. I am mowing a hair more than 3 acres. The mower works great when clean. Just frustrated. Any advice besides selling it?
Mow when it's dryer.
What kind of blades are you using? |
Dry, wet, it just does not matter. Very frustrating. Original blades were high lift. Tried Cub Cadets gator blades. They were no help and did not cut as well. Went back high lifts this spring. If there is a different blade to be tried- by all means let me know. Have a lot of clover in the grass. Some say that is an issue. Never had a mower which had to be scraped out so often. I have filled 2- 5 gallon pails with grass scrapings before. And that is after 4-5 mowings. Thinking about spraying 2-4-D to nuke the clover as a last ditch effort. Otherwise, the mower is going.
Odd that this thread should come up right now.
With so much rain lately I have had the same problems, and I'm not about to wait until August for the grass to be dry enough to mow. My question is: Has anyone ever used "Slip Plate" on the underside of their deck/s with good results? Sorry to hi-jack your thread.
Gaters are good on dry grass and fantastic for mulching leaves .
I use regular blades on wet grass, as it tends to throw the grass out better. I just finished moving and scraped 3 aluminum scoop shovels from my deck, Chickens love it but not me. I scrape the deck after every mowing. It is easy for me as I have an air operated chain hoist I got 3" or rain Y day so it is wet even standing water in a lot of places. Deere Deck same way. nature of the beast I figger. No problems in hot dry August. |
Did you try and mow at a higher setting? I understand you with all the rain you have to mow when you can.
Brian April 1979 1200 Quietline 44A deck 1988 1211 customized into a 1288 with a K301AQS 38C deck and a 1864 54” deck . Snow blades 42" and 54" . Brinly disk, brinly plow a cultivator and a $5 brinly yard rake!
