Old 07-05-2015, 07:34 PM
j4c11's Avatar
j4c11 j4c11 is offline
Default Mag 20 PO Mod
Removed the Mag 20 off my 2072 today to address what I believe to be an oil leak from the oil seal behind the flywheel. Took off the valve covers to take a peek and found a curious PO mod. It appears that silicone was used to form a "mushroom" around the push rod, and also there is a hole in the middle that was completely plugged. The valves are functioning normally(their movement is not hampered). Any idea why that's there? The other side doesn't have them. Should I remove them?
On a separate note, anything else I should consider replacing while the engine is out of the tractor?
Old 07-05-2015, 07:39 PM
Justin Witt Justin Witt is offline
Looks like JB weld. Not sure what the hole is in the center. Possibly just a breather is what I would guess. Maybe Jon can answer that. But that defiantly looks like JB weld hi temp.
Old 07-05-2015, 07:52 PM
j4c11's Avatar
It has a soft rubber like consistency, it's more like RTV silicone than JB Weld.
Old 07-05-2015, 07:55 PM
Yes, you need to remove it. PO's
Make sure the drain there is unplugged, and none of that crap plugs it again. It's silicone.
Old 07-05-2015, 08:43 PM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
that's messed up
Old 07-05-2015, 08:47 PM
Terry C's Avatar
Terry C Terry C is offline
What do you think that PO was trying to accomplish?
Maybe he was trying to quiet the valve train.
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
