Recently got a 149 to try to revive....first cub I owned in 20+ years.
looked underneath and the link on the deck frame that goes over the rod is currently on the rod at the foot rest....I can also see where there is wear on another shaft under the tractor where it once was which I think is the shaft for the lift.... Question is which is the proper place for it..... |
Is this what you are looking for..??
Yes....but what rod is that arm with the forked end around.??
I know there is a round rod that is welded under tractor that goes out to the foot rest and also another shaft just a bit higher that I think is part of the lift mechanism..... Both of them on my tractor shows some wear on them so I am guessing that in the past they were both used....just not sure which is correct. |
Thank You very much !!!
I am sure this was just the first of many more dumb questions.....LOL |
The only dumb questions, are the ones that are not asked.
We quit learning when we take the last breath.
That's a really good pic for explaining several things. Is that in the tech library?
Darkminion (Lew if I'm correct?)
Here are the pic's of the carriage & mule drive connected to the mower deck. IMG_0331.JPG IMG_0332.JPG IMG_0333.JPG IMG_0334.JPG IMG_0335.JPG IMG_0336.JPG Hope that helps. Mike |
I will be playing with my deck collection tomorrow and will see if I can enlighten you.
But I do believe you need a different pickle fork hanger thingy.
At first I thought the "pickle fork" was worn out and broken off..... but since you said that I would say that it has a WF mule, with a NF subframe. I've played around with combining the two before to make a deck work on another tractor..... more headache than it was worth to just find the right one. |
