Old 08-05-2015, 09:05 PM
freedhardwoods's Avatar
freedhardwoods freedhardwoods is offline
Default Rear Weight for FEL
A lot of you can make some nice looking as well as useful things. I'm not so good with nice looking, but I can usually make something work. Put that together with the fact that I save all kinds of "junk", and you get something like this.
3 brake drums and several brake rotors all held together with a couple bolts in a 7/8" bar. 470 lbs.
Old 08-05-2015, 10:22 PM
bocephus1991's Avatar
I don't know what you plan on doing, but I wouldn't put anymore on her! I'd load the tires and try to buy or get the weight on the tires and off the frame, lift arms and wheel bearings. It will work, just kinda hard on equipment. Least it's not like this picture
Brian
Old 08-06-2015, 08:15 AM
I will start by saying I don't baby equipment or tools. I use them and sometimes abuse them. That causes things to wear out and break faster. That is why I am a little picky about maintenance.
I won't argue against loading tires. In some situations I would do it myself. For right now I need to be able to quickly switch between a light footprint for some jobs and a good heavy counterweight when using the loader.
The main reason I generally don't like the idea of loading tires is because you lose most of the cushioning/suspension effect of only air in the tires. Shock loads (hitting a bump with no cushion) are much more damaging than steady heavy loads. Loaded tires in severe conditions is harder on everything than any other kind of weighting.
If you had 2 identical pickups, one with a 300lb weight in the front of the bed, and the other with 75 lbs of liquid in each tire, you would be shocked at the difference in the ride. The pickup with loaded tires would be breaking parts much faster than the other one.
Weights bolted to the wheels would be the ideal "semi-permanent" way of ballasting, but that isn't fast or easy to switch back and forth.
I didn't realize it was going to weigh that much when I put it together, but I'm not at all worried about hurting anything. It doesn't even weigh 1/2 of what the lift arms are rated for.
As far as wheel bearings are concerned, dirt and improper adjustment causes damage. Weight only causes them to wear a little faster. And yes, wear does lead to improper adjustment. A good preventative maintenance schedule will catch loose wheel bearings.
Old 08-06-2015, 02:40 PM
As best as I can count, the guy in the pic has 96 weights hanging on that poor little JD. At 80 lbs apiece, that's almost 7700 lbs.
Old 08-06-2015, 07:01 PM
Group_44's Avatar
Group_44 Group_44 is offline
And I just scrapped a bunch of old truck disc brake rotors.....What was I thinking?
2082 w/60" Haban Deck & 450 Blower,AGs,weights
2084 w/54" Deck & 451 Blower
2086 w/54" Deck, 54" Haban Snow Blade
1864 w/54" Deck and weights
1641 w/48" Deck
1650 w/44" Deck parts Tractor (getting smaller all the time)
445 John Deere w/ model 40 FEL (went over to the dark side)
Old 08-06-2015, 07:13 PM
Terry C's Avatar
Terry C Terry C is offline
[QUOTE=Group_44;340556]And I just scrapped a bunch of old truck disc brake rotors.....What was I thinking?[/QUOTE
You were thinking you didn't want to break the rear of your cub
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 08-06-2015, 08:51 PM
Rule number one - Never throw anything away. I have broken that rule a few times myself and then kicked myself later.
I suppose I don't technically belong on this forum because my tractor is a little bigger than most garden tractors. Maybe that is throwing a few people off. About 200-250 lbs max would be more suitable for a regular garden tractor.
I'm not the first one here to add weight to the back of a tractor.
http://www.onlycubcadets.net/forum/s...ad.php?t=36457
http://www.onlycubcadets.net/forum/s...ad.php?t=35539
http://www.onlycubcadets.net/forum/s...ad.php?t=28298 - Read post #8. Wheel bearings aren't such a weak link as some (in many forums) seem to think.
http://www.onlycubcadets.net/forum/s...ad.php?t=28705
http://www.onlycubcadets.net/forum/s...ad.php?t=28639
