Old 08-12-2015, 12:29 AM
KiwiUSA KiwiUSA is offline
Default New member and new Cub owner
Hi all, I joined a month or so ago but was waiting till I got my Cub before saying hi. I got a Cub 105 as payment for labor and parts on a Honda Goldwing GL1100 I was getting road worthy for a friend.
Even tho it is my first Cub Cadet it is my second lawn tractor, my first being a 1983 Snapper LT11 which I restored, I will post a pic of that at the end of my post in case you stop reading right now lol.
I have a lot of questions concerning the 105, was it a good model? It comes with a tiller, snow blower and mower deck, it has been repainted years ago and was never finished being put back together,
It will need new new wiring and replacement of a lot of nuts and bolts, voltage regulator, ignition switch, coil and seat. The old parts may work ok but new is better, it also came with new decals which need to be stuck on.
I believe the 105 was the first model that had the hydrostatic trans and were made between 67 and 69 correct? There is a little lever at the bottom front of the seat on the right side, is that a lift lock?
Anyway there will be question forth coming in the future regarding where the hell this part or that part goes and looking forward to getting to know you all. I will get pics soon of it and add to this post.
Thanks for reading this long winded intro and yep....here comes the snapper pic heh heh
Old 08-12-2015, 05:08 AM
IHinIN IHinIN is offline
Welcome. The 123 was the first Hydrostatic Cub. The 105 was in the next series along with the 125 Hydro and the 104 and 124 gear drives. The lever by the seat presses on the relief valves so that you can push the Cub when it's not running.
Old 08-12-2015, 10:43 AM
Aww look, its a little baby tractor. just messing with you, that's one shiny snapper. The 105 is a great tractor and will serve you well. Congrats.
Old 08-12-2015, 11:05 AM
Terry C's Avatar
Terry C Terry C is offline
Welcome to OCC. If you do as good a job on the 105 as you did on the snapper it will be cool I'm sure.
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 08-12-2015, 09:12 PM
Got some pics of it
Old 08-12-2015, 09:47 PM
Terry C's Avatar
A set of stickers and a new seat and you're in business
105/125 is my favorite because of how they look, and yours is pretty
darn good there.
The technical library on this sight is quite nice. Give it a try.
By the way your snapper is a lawn tractor and your cub is a garden tractor
You even have a rear lift and the gearbox for a tiller there! Bonus!
But you are missing a couple of pieces that goes below the seat at the rear, it bolts to
both fenders, and a small thin piece of sheet metal that bolts to the rear cover. PO probably took them off to put
on the rear lift. See if they are around yet, if not no biggie you can pick them up at one
of the sponsors on the top of the page
Terry
3225
