Old 08-20-2015, 10:45 AM
FrankF3's Avatar
FrankF3 FrankF3 is offline
Default Wiring Question
I'm in the process of replacing the wiring harness on my 782D. I got ahead of myself when I got around the instrument panel. I think I've got MOST everything reconnected except for the hour meter. One terminal on the back of it has a plus (+) symbol next to it. Looking at the wiring schematic, I have one terminal that has 2 wires a red one and a white wire that has +12V on it when the key is turned on, and the other terminal with green wires that is ground. The red/white wires should go to the (+) marked terminal?
1989 - Cub Cadet 1772
38" Lawn Sweeper #196483
60" Haban Mowing Deck #196374
Old 08-20-2015, 11:26 AM
Red & White wires goes the the ( + ) terminal on the Hour Meter. The Green wire goes to the ( - ) terminal and is ground.
Old 08-20-2015, 12:32 PM
FrankF3's Avatar
Thanks Roland, I suspected that but just wanted additional confirmation of it.
