Old 08-25-2015, 04:18 PM
BIG RUH BIG RUH is offline
Default Decal removal
What is the best way to remove the old decals and adhesive from the side panels on an 1862?
Old 08-25-2015, 04:23 PM
Heat gun to get the decals off and rubbing alcohal to remove the adhesive, its a slow process but it won't damage the paint.
Old 08-25-2015, 04:26 PM
RR1862CC's Avatar
RR1862CC RR1862CC is offline
Until I bought a remover tool I used a heat gun or hair dryer then cleaned it up with Glue remover or lacquer thinner. This is on metal bodies not plastic. I would think the same would work on the plastic but not use too much heat.
Allis Chalmers 416
Massey Ferguson MF-8
Brinly 10"plow
Old 08-25-2015, 05:01 PM
me too....
Old 08-25-2015, 05:22 PM
RR1862CC's Avatar
The glue remover we used was a 3m product sold at NAPA. We now use a slow speed pneumatic grinder that uses a rubber wheel to take them off. Best tool ever! NAPA sells the same type wheels to use in a drill but you have to use a slow speed.
Allis Chalmers 416
Brinly 10"plow
Old 08-25-2015, 05:41 PM
I use a heat gun and prep-sol
Old 08-26-2015, 12:49 AM
bocephus1991's Avatar
You could try wd-40, not good for much else! Lol
Brian
Old 08-28-2015, 02:35 PM
I got a bottle of adhesive remover at O'Reilly's called Goo Gone. Put some on a clean rag wiped the adhesive with it. It took a little rubbing, very little and everything cleaned right up. Counter kid tried to sell me a can of airisol adhesive remover at the price of $20. The Goo Gone cost me $2.99
Old 08-28-2015, 05:42 PM
inspectorudy's Avatar
I've been redoing old JD's for several years and I use a heat gun and WD 40 for the remainder of the adhesive. It works on 40 year decals and if I need to I use one of those Bondo spreaders made of plastic for the decal since it wont leave any marks.
1811 Hydro
