This past weekend we took full advantage of the many yard sales going on in our area. One thing we ended up with is an old kids table and chairs set that needs some refinishing. The top is worn to bare wood and cupped. What is the best way to straighten the top? I was thinking of using 3/4" x 1/12" strips screwed across the bottom to pull the top flat. I am worried that just pulling it flat will result in the top splitting or cracking. Is there a trick or method that will prevent that? It doesn't have to be perfect, just flat enough that toys wont rock when they are put on top.
IMG_2762.jpg IMG_2763.jpg IMG_2764.jpg Thanks for any ideas Bill |
Rip the top lengthwise into as many boards as practical. Re-glue with a spline joint or biscuits. Make sure the end grain alternates when you re-glue.
Moisten the top side pretty good then put it in the hot sun upside down.
it should warp back flat, then glue & screw a couple of strong backs on the underside and refinish
You can also add some weight to help speed up the process
Or you could go to Lowes's and get a 1/4 sheet of plywood and be done with it.
Leave it alone. If the kids spill on it the stuff will run to the center.
