Old 09-27-2015, 09:01 AM
mike c mike c is offline
Default Removing electric PTO clutch.
I have a model 1811 cub. It has a kohler magnum 18 engine I'm trying to track down a oil leak. It looks to be leaking behind the PTO Clutch. I'm not sure how to get the Clutch Off. Can someone help me ?
Old 09-27-2015, 09:23 AM
j4c11's Avatar
j4c11 j4c11 is offline
There's 4 bolts that go into the block and one bolt in the driveshaft. Two of the bolts that go into the block also support the muffler so you will need to take the muffler off. You will need an impact wrench to get the center bolt out, otherwise the driveshaft will spin with it. Once you get the 5 bolts out you should be able to just slide the clutch off the driveshaft.
Here's instructions with pictures for a Command engine, but it's the same on the Magnum I'm assuming you have:
http://www.onlycubcadets.net/forum/s...ad.php?t=33411
Old 09-27-2015, 10:23 AM
Thank You for the info, I Took all of those bolts out Yesterday, And tried to slide it off but it wouldn't slide off. I will Try prying it off .
