I tried to fill up the hydro on my yellow 982. Dipstick right behind the battery under the seat. Apparently, there's 2 types of these; mine has the elevated fill tube. Anyhow, using a funnel, whenever I pour a little bit of fluid in, it covers over the small hole, and moments later the machine releases a big burp, spewing most of the new fluid out, all over the machine. Any more than a tiny drip gets puked out. with a 2 gal jug, that's not easy. Is there a secret to doing this with minimal spillage?
Stick your funnel in the fill hole, take a small tube and feed it through the funnel into the rear making sure to leave some sticking up above the funnel. This allows the air to escape from that tube and your fluid to go down unimpeded.
-Ryan
When using a funnel, offset it so it only covers half of the hole. Don't push it down in the hole. You will have to hold onto it. This works by letting hytran run down one side while letting air escape as needed. This process has worked for me. Takes awhile, so patience is a good thing.
Josh Diesel Cub Cadets........... |
I have used the small tube through the funnel and it works so much better than getting a face wash from the annoying burps.
With my son, EricR Super 2084 with 54" mower, 451 blower. 2086 with 3 pt hitch, 54 inch deck, 551 blower, 54 in brinly blade. A 4 digit original w deck. A 70 with deck. 2 102s both with 42 in decks, one with creeper, 1 36 inch IH snow thrower CW36, 1 42 inch IH blade. 149 with mower. 2072 w 3 pt hitch, Johnny bucket, 60 in mower, 451 blower. Jacobson GT 10 with mower. DR Lawn vac tow behind,Home made lawn roller. Brinly cart, 2 off brand carts and 1 home made cart. |
Yep strange design feature/bug.
I like jimbob200521's idea, great ingenuity. I'm off to ACE for $1 worth of tube...... |
Just go as slow as you can, and use a funnel. Other than that not much you can do.
'74 IHCC 108 - 38A, supersteer axle '75 IHCC 1000 - 44A, Sears wheel weights '87 CC 1872 and 1811 - Haban, 44C '96 CC 1863 - 54GT '79 JD 400 - 60" deck "Projects" '67 123, '65 102, '71 126 |
This is normal then?
Yes. I have removed the access cover to the hydro release valves and removed one of them just enough to prevent the famous burp.
Adrian 2072 (789513) |
Perfectly normal, and extremely annoying.
| Tags |
| 982, fill, hydro |
