Hi Guys,
I have a Cub Cadet GT 2148. Cuts grass really well, but the dust and dirt seems to get into the air intake and really make a mess of the filters. Any suggestions how to fix this problem? Pete |
I don't really see anyway to avoid having that happen. As long as it's not getting past the filters I wouldn't worry too much about it. I'm sure you're having to change the filters more frequently.
Adrian 2072 (789513) |
Wash the foam filter out using dish washing liquid and rinse well , a light spray with foam filter oil
Wash and clean filter cover and give filter a good brush/blow (not compressed air) Reinstall Have to do this frequently/every time as part of my acreage is dusty Regards Oz Hope this helps more than a funny face (lol) |
The filters are doing the job intended. You would only have a problem if you had no filter installed. Do as Oz suggested and you'll be fine.
When the paper filter gets dirty enough I replace it. The foam filter can be serviced as Oz said. If you choose to brush the paper filter, be sure not to damage the filter material. Remember, a new filter is much less money than an engine rebuild.
Randy Cubs: 71, 72, 127, 149, 1440, 2186 and 1864 John Deere 110 round fender John Deere 140 H3 Sears: GTV16 |
I do not suggest brushing a paper filter. It is fine to blow them out with compressed air. Just don't be stupid. Keep the blow tip at least 4 to 6 inches away from the paper.
It's an air filter.... it's gonna get dirty. That's what they are for. |
I'll try to make this simple, air filters are cheaper than engines.
1641, 1541, 682 with 18hp command engine and hydraulics from a 782. 1872 with a power angle blade. |
