My Kohler went kaput last weekend and looking to replace the engine. I have looked at Smallenginewarehouse.com & they no longer have a Honda kit for it, they told me the Hondas run hot & Honda doesn't make stuff for this kit any longer, and all they have is the Vangaurd series from Briggs & Stratton. I have thought about finding a Kohler Command & make it work, and have thought about the B&S kit to replace. Opinions....?
Also while I'm at it, why not give it a little more HP, SEW has B&G kits for other Cub Cadets in 23 hp versions, will they work in the 682? These for example says it is for a Cub Cadet 1811, 1812, 1860, 1861, 1862, 1872, 1882: http://www.smallenginewarehouse.com/...tegory=1709590 Are they the same as the 682 only more power? Looks like the shaft is different though. I have been reading posts here about engine swaps, just looking for some more opinions. Thanks Scot |
The bigger engine will work. The other listed tractors are the same style.
Harbor freight has a Honda clone. It can be made to work, if you can do a little fabricating.
http://www.harborfreight.com/engines...epa-61614.html |
Am I being silly now, 28hp fuel injected Kohler...... (insert Tim allen grunt here)
http://www.smallenginewarehouse.com/CH745-0113-TO.html |
-can't afford it -are a sissy girl |
It goes along with pretty much every car I have ever owned. I have converted 3 of them to fuel injection & more power. Current project, 1986 Monte Carlo SS, stock has 180 hp carbed 305 5.0L, converting it to a 450ish HP 6.0L LS2.
I put a 20HP Vanguard in my 782. Easy swap.
Let's hear more about the Monte. I've got an '88 SS here, and a 383 with AFR heads and a roller cam sitting on the hoist. It needs EFI bad.
RUN IN THE RED 782 w/50c deck (red); 782 dual stick, 44c deck (y/w); 1050 w/38c deck; 1864 w/54" GT deck; 1872 project Cub Cadet Pro Z 560 L 42" power angle snowblade, #2 tiller, 2-QA42a snowthrowers, 450 thrower, #2 cart; 54" Haban blade; Brinly box blade, 48" dethatcher, moldboard plow; Agri-Fab sweeper 1200, 1863, 1864 parts machines |
