Old 11-26-2015, 08:54 PM
bsb369 bsb369 is offline
Default Bought my first smoker CCC 882
Just bought my very first diesel cub today an 882. It's in fair shape missing the side panels but runs great and the 44 inch mowing deck is quite as a mouse only 1142 hrs. I did notice that it had a few leaks under the rear end. I don't know a lot about this model anything I should check for or any known problems inherent with this model??.
Old 11-26-2015, 11:35 PM
PeterJ PeterJ is offline
Congrats on that find! I had a 1512 (same model just newer - 1986?) for 20 years. I just sold it this summer to someone that approached me to buy it. When I bought it in 1995, the hour meter had been replaced and it had new rear tires. I think its first 8 years of service was full time commercial duty. It had LOTS of hours on it. I put about 600 hours on it. You will love the Kubota.
I replaced the hydro relief valve on mine, back in the '90s, because it was leaking fluid all over the rear end. That worked for a very short while and it started leaking again. I just kept a piece of cardboard under it from then on. Maybe the power or vibration of the Kubota has something to do with the leaking? I don't know.
It starts MUCH better if over 40 degrees - I fought it for 4 years and then put heat in the shop and everything was fine after that. Make sure the cables are good and your have a strong battery. Interstate makes a good one that will fit in the small space.
About five years ago I started having fuel issues. It would run for about 5 minutes of snowblowing and would run out of power. Shut it off for a few minutes and it would run again for about 5 minutes. It ended up being "floaties" in the fuel tank.
Just follow good maintenance practices and if it is in good shape that 30 something year old garden tractor will still last for GENERATIONS. If you run into a problem just ask here if you need help.
PeterJ
Old 11-26-2015, 11:40 PM
Congrats on the tractor
I would check the bolts that attach the diff to the frame and make sure they are not loose or possible broke. It (your leak) could be axle tube or rear cover gaskets also. You'll just have to clean everything and see what you find.
But the first thing would be the diff attachment locations...
Good luck, the experts should be along shortly with other opinions.
Old 11-27-2015, 01:36 AM
Rescue11's Avatar
Rescue11 Rescue11 is offline
Congratz! looks like you have some good advice already!
1- 1200 in pieces
1- 1864 in pieces
Old 11-27-2015, 06:14 AM
I really appreciate the advice I pulled the center cover off that's between the seat and the dash and sure enough it does look like it is leaking around the relief valves next I will check the differential bolts on the frame and in the rear cover. Once again, I really appreciate your advice you guys are great on here
Old 11-27-2015, 08:15 AM
Terry C's Avatar
Terry C Terry C is offline
Congrats on your 882!
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 11-27-2015, 08:18 AM
Just curious will any 82 series sleeve hitch work on this machine??
