Last year plow setup worked ok, but a hydraulic setup would work much better.The old setup used a winch which has a little too much drift and you had to get off the machine to angle the plow (PITA).
125Plow5.jpg My friend saw a 105 and asked if I was interested in going to look at it. When we went to see it, the people said it didn't run and there was a plow setting on the junk pile. they asked how much I would give and I said $100.00 for the tractor and the plow.They said ok get it out of here (they were going to scrap it). [105Start.jpg 105Start2.jpg I cleaned the plow and did a mock up to see how it would go together. here's the parts I used. PlowParts01.jpgPlowMockup01.jpgPlowMockup01A.jpgPlowMockup01E.jpgPlowMockup01D.jpgPlowMockup01F.jpg Next was to paint the parts. PlowPaint02A.jpgPlowPaint02B.jpg After some trial and error, I found a place for the pump, control valve and reservoir tank. HYDRAULICGEARPUMP.jpg Chief 2 spoolfloat.jpgHydraulicOilTank.jpg Things are coming together. PlowHyd01B3.jpgPlowHyd01C.jpgPlowHyd01A.jpg PlowHyd01B.jpgPlowHyd01B2.jpg Install the plow and cylinders. PlowInstall01B.jpgPlowInstall01C.jpg PlowReadyA.jpgPlowReadyB.jpg Take it outside to see if it works. PlowReadyC.jpgPlowReadyD.jpg Yup, works good. Moves ground and the power angle works great. Happy, happy, happy. ![]() Only one problem, the cylinder for up and down is too slow on the float for plowing snow (ok for ground work). I put a smaller cylinder on it, now it's fine. PlowReadyModB.jpgPlowReadyModC.jpg Attachment 71431 Let it snow, I'm ready.
Patience is the key to success . The difficult, I'll do today . The impossible, I'll do tomorrow
great work looks good to me
982D kwik-way loader w/3 spool control and front and rear remotes,2182, 1812 cat 0, 1440 puller, 3185 grass killer, 2x 450s, QA42, 364, tiller |
Nice set up and clean fabrication skills
![]() Jeff |
Thanks guys, appreciate the comments.
Very unique and look pretty functional! Well done darryljs!
Gilles. 1988 2072 401 54" hyd angled blade 1988 1872 364 snowblower/C50 deck 1976 1650/QA42A blower/44A deck/standby 1976 1450TS/Sleeve hitch/44A deck/in storage 1963 100 (red)/in storage 2010 Kubota 2380-2/42" infinity deck (engine swap) |
Nice work, looks great!
