I may buy a dual spool valve for my 782 I was told it came off a 782. My question is I don't think the steel hydro lines that are on my machine now will work. What would be the best way to deal with this. The guy with the dual valve does not have the steel lines that went with that valve
If you have a flare tool and a tubing bender you can make new ones pretty easy.
yea guess your right, would those lines even need to be steel could you use another material that would bend easy?
Most people use 3/8" steel brake lines. The max pressure of the Sundstrand Hydro is 600 PSIG.
You also could use a combination of Steel Brake line and hydraulic hoses.
What do you mean by that George?
No, not really...
