Removed the 782 starter last weekend after diagnosing inconsistent starter performance. Removed starter, disassembled, cleaned and reassembled. Ran out of time last weekend to reinstall, but got it in yesterday.
What a difference! Now, the starter kicks over each time (like it's supposed to). Finished up with new points/condenser, plugs, fuel filter, fuel tank shutoff, oil and air filter. Installed the deck and took it for a practice mow. Works great! ![]()
Stanton 1980 IH 782, Kohler M18 IH #1 Cart, original IH 42" Blade, modified to 50" and hydraulic 2015 XT2, Kawasaki 23 HP |
Glad to hear it!
Congrats on the repair...
Make the best of each day , Todd ![]() Original's Face Lift thread.http://www.onlycubcadets.net/forum/s...ad.php?t=34439 (O) Start to Finish video.https://www.youtube.com/watch?v=GAoUNNiLwKs Wheel Around videohttps://www.youtube.com/watch?v=XUL-m6Bramk They can't all be turn key! ![]() |
What all did you do to the starter? My 782 is just spinning without engaging. Engages about every 20th time. Seems like I cleaned it about 3 years ago to " fix" it. Been starting to act up since last fall. Only start it every so often as my blade is on my other garden tractor and the 782 sets most of the winter.
Take the starter off and apart, clean it inside and use fine emery to clean the end commutator, check the brushes for length, replace if necessary, lube the bushings with light weight oil.
A few drops is sufficient,more is not better, reassemble and clean the helical spline and relube with 52-357-01 it costs about $4 and is what works best @ all temps. Reinstall/enjoy. All this is covered in the overhaul manual ![]() |
YAY!!!!!
![]() Quote:
