I have a 782 I picked up on the cheap that I want to put the sickle bar mower I just got and yesterday. I thought I would be able to finish it up. I swapped in a Mag 18 from a 1872 and was finishing it up and noticed a slight oil leak at the crankshaft seal behind the PTO clutch so I picked up a Kohler seal, cleaned the bore well and installed it dry as recommended. I reinstalled the PTO clutch and muffler and after I finished the rewire so I could shut down the Mag engine I started it up. As soon as I revved it up I noticed a lot of oil dripping out from under it. I removed the grill and the whole inside of the cooling shroud was covered with oil. I was very careful installing the seal and lubed it before installing. I was so upset, that I locked up the shop and went in the house. This engine will carry 80 psi oil pressure when first started and I am wondering if the high oil pressure is causing to much oil to be flung off of the main bearing and the oil return cannot handle it. The end closure plate has much RTV oozing out around it from the previous owner and I am also wondering if the oil return might be plugged. I guess I will have to remove the engine and remove the closure plate and check it out. I also need to look into the recommended oil pressure. O well I was hoping to start on my 1872 build this weekend.
Later Tom |
That sound like way to much pressure, I believe the manual says it should have no more than 50psi but don't quote me on it. I had a mag 18 that carried 60psi and I had to replace the lines running to the oil filter and when I did it only had 40psi, turned out one of the original lines was collapsed on the inside causing restriction.
make sure you purchased the correct seal. I believe some people have accidentally ordered the one for the flywheel end and it's a different size
Adrian 2072 (789513) |
It turns out that the parts store ordered me the wrong seal. I looked it up my self on line today and came up with a different number. I decided to remove the engine from the tractor and get it up on the bench to work on it and as soon as I removed the PTO I could see that the id of the seal was to large, but the od was correct. If I would have just checked the id against the old one I would have noticed the difference. My mistake for getting in a hurry. The worst thing is if I had looked in my spare parts cabinet I already had the correct seal. Lesson learned always check to see if you have a spare and also do not get in a hurry and install new parts with out making sure they match the old ones. I am usually good about this but got in a hurry.
![]() ![]() ![]() Tomorrow I will get it back in the tractor and hopefully get a chance to get my sickle bar mower attached. I have a thread on it in the implements section. Later Tom |
Update on the Mag 18 saga. Yesterday after I installed the new seal and reinstalled the closure plate I decided to do a leak down test on the Mag 18 before I reinstalled it into the 782. The engine has 120 psi compression but the right cylinder has a intermittent miss and I decided to find out the cause. Left cyl has 10% leak down, right cyl had just over 20% Both leak out the exhaust. So I pulled the valve covers and noticed that the rotators are on the intake valves instead of the exhaust and the exhaust valves only have .006 of clearance. I an wondering if who ever rebuilt it switched the jugs side to side when he reassembled it. So I picked up two new head gaskets and I will remove both heads, remove the valves to see if they are not mixed, hVe the valves faces and touch up the seats. I do not want to have to remove this engine again. I will let you know what I find when I get it tore down. So much for a quick and easy engine swap.
Later Tom |
FWIW:
The left and right jugs are a bit different on the M-18's as far as the right jug has the bosses for the mounting of the mag. ignition milled flat and drilled/tapped so it can be mounted. The left side only has the cast bosses, it lacks the machining. The seats on the exhaust are hardened, the intakes are not. The latest/later M-18's had 30* ex. valves/seats,and they use different clearances. it is covered in the service manual section 10. If you don't know, you have to grind the valve stems to adjust the clearance. look the manual over, before you dive in. I doubt the heads were switched, possibly the "mechanic" installed the rotators on the intakes mistaking them for the exhaust, and set clearance accordingly.just my guess. --- a helpful hint. Be careful pulling the valves out of the guides so you don't damage the intake valve seals, they are pricy. If you get as far as setting the clearances do it with the seals removed saving the repeated in/out while checking/grinding of the stems. #95 compression is about average. |
