Old 04-16-2016, 02:29 PM
SS5150's Avatar
SS5150 SS5150 is offline
Default Anyone have a new XT3?
Just stopped by my local Cub dealer and they had a new XT3 GSX with a 54" fab deck on it. Dealer let me take it for a little spin around the lot. Seemed pretty nice, tight turning radius, Command engine, diff lock, elec power steering and lift. Wife & I are in the process of buying a 3 acre property that is mostly grass, with some trees mixed in. Wife is already freaking out about the time spent mowing (which I look forward to). Anyhow, anyone here run one? What are your thoughts/opinions? I know we are mostly older machines here on OCC (which is why I spend time here) but I'd appreciate some feedback.
As it stands I'll be tackling the property with my 1861/54GT combo and my 782/50c for back up, although both of my 782s are a bit tired. The dealer also had a 2186 on consignment, but asking $800. Thought it'd be a good organ donor until I heard the price.
RUN IN THE RED
1872 project
Cub Cadet Pro Z 560 L
Old 04-16-2016, 05:12 PM
CubDieselFan's Avatar
I have not seen the XT3's, but I might think about putting a new engine in one of the tired machines, before I spent that much on a new mower. I know that does not answer your question. Like you said most here like the the older machines. Do a search of the XT1 or 2, someone on here bought one last year. What is the price of the XT3?
Old 04-16-2016, 05:58 PM
SS5150's Avatar
$5200 otd with a 54" fab deck. My plan is to put the Mag 18 & 54" from the 1861 under my CCC 782. I'd like to do a Command v twin & power steering conversion as well, but its time & money, time being the hard part to come up with. This XT3 would be turn key & the wife potentially could run it.
An 1864 would give me what I need, they're just hard to find in good shape.
RUN IN THE RED
1872 project
Old 04-17-2016, 02:18 AM
I do not know anything about that model, but when I purchased my Cub Cadet zero turn in 2008, I looked at the different model spec sheet. The 48" commercial model was decked out with the best options, so I wondered why the 48" model had the best options over the 54" cub cadet and the 60" cub cadet. I was told that the 48" is the favored one among commercial mowers because it gets in the tighter spots, around trees, and still mows the open spaces quickly. The 54" and 60" are faster at the open spaces, but not every yard that the guys who are mowing for a business encounter is a wide open yard. They also told me to expect about 15 years out of it, so here I am 8 years later with 115.5 hours on it and only had to replace the deck belt on it, beyond regular maintenance (battery, oil, filters, etc.). I mow 1.5 acres and only use that zero turn to do it.
I would consider the yard and future plans for it (are you planting more trees or cutting trees?....Sorry, I did not help you with your specific model, but I hope I have offered some things to consider.
Old 04-17-2016, 07:43 AM
drcjv's Avatar
drcjv drcjv is offline
I will again state the obvious. For the cost of the new machine you could buy several old machines or fix the ones you have to do the job and have plenty left over. I just sold an 1882 that was as perfect as you could get for $2600 That leaves a lot left over for other things that might be needed at a new property. But it also really comes down what you really want. Financially the older machine might make sense. I have purchased many used vehicles and equipment but there are times when only new will do. When I bought my New Holland TC33 I did not want a used tractor. I have a new mustang on it's way from Detroit right now because That is the model I wanted. I would guess you already know weather you really want the new one or not. Now like most of us we have to convince our selves that we should spend the money on the new machine. I say if you can afford it and you want it than get it.
Charles________________________
1572 3pnt, rear PTO, 50" deck
1772 3pnt 50" deck, Brinly Plow, 54" Power angle plow
1872 3pnt, 44" deck, Brinly Plow, 54" Power Angle Plow
2072 3pnt 50" deck, Brinly Plow
2072 50" deck
Cub Cadet Tank 50 Zero Turn
Cub Cadet 33" Commercial Walk Behind
1953 Ih Cub with just about every implement
New Holland TC33D with Loader and Backhoe
Old 04-17-2016, 09:19 AM
Shotgun Wedding's Avatar
Shotgun Wedding Shotgun Wedding is offline
Buy it, you will not be unhappy. If you have the cash, do not hesitate.
I have the model name 2 years older, exact same tractor but different color. It is a sweet machine.
