I have a cub 1604 with a Briggs & Stratton engine that is not charging. When the PTO is turned on, the amp meter is in the negative range. Any help would be appreciated.
Robb |
Do you have a DVM or VOM..??
What are you asking? Please be more specific.
He want to know if you have a volt meter, if you don't know what that is just click the link.
http://www.active-vision.com/aca-dvm...FVBZhgoduvgHeQ
Sorry...
DVM = Digital Voltage Meter VOM = Volts - Ohm Meter (Analog)
You'll need the meter in order to test the stator and the regulator. This pic is from a Vanguard but your system is pretty much the same. The regulator should be on top of the engine under the air cleaner if memory serves me.
Problem solved found broken wire
