Old 04-30-2016, 01:28 PM
Default It's alive!!!!!
I got a command 20 a while back with less than 400hrs on it and I've never heard it run till today. Man does it run. After a fast carb clean, it fired right up with no smoke and it really sounds awesome with no muffler. So, my question is what do I need to drop this in a 1811 chassis or this 1282 I have sitting here? I'd also like to know what model cubs I could steal a PTO off of, since this one is missing a few parts?
Old 04-30-2016, 04:23 PM
So here's what I have so far. I took the engine plate out of a parts 1811 I have sitting here and put it in the 1282 chassis, the Drive coupler off the original 1282 engine bolted right on so I set the engine in to take a look. The drive shaft appears to be about an inch to long and it had a real slight misalignment but I put a washer under the back of the engine to raise it up and it looks much better. I test fit the side cover and it looks like I will have to run an electric fuel pump because the mechanical pump hits the side cover.
Old 04-30-2016, 05:11 PM
bocephus1991's Avatar
Looks like your off to a good start. I see you still have the screen under the frame. I took mine off my 1211. I'd rather have the crap fall out than build up on there a cause a fire or something. That 1282 should have plenty of power to do whatever you want!
Brian
Old 05-01-2016, 10:24 AM
mickb72 mickb72 is offline
Default cub
Hello, the pto off a KT17 fit on one i did. CH had 1-1/8" crank and was about a 1/2" short, i added a spacer. Mike
Old 05-01-2016, 11:36 AM
Tim,save the motor for one that will need it like a super,unless your making a puller out of the 1282...
Old 05-01-2016, 09:50 PM
Nope no puller but it will make one heck of a grass killer, I also have the rearend from an 1811 and a 2 spool valve I want to install to do away with the manual lift. I'd like to use the 1282 for mowing and the 1211 for plowing, as far as putting it in a sgt I prefer the size of the gt to the sgt.
