Old 05-13-2010, 10:54 AM
nikster's Avatar
nikster nikster is offline
Default Clean up question?
Well I posted a photo of my #109 & am starting with the basic's in cleaning it up a bit.
Can anyone comment as to the method i'm gonna use. I searched the the site & gathered whatever my febble mind would absorb & came up with this combination of idea's.
1st. Gonna raise it up enough to get under it with ease for my stout body. My wife calls me a 'lard arse' but thats just her. Once I can easily get under the 109 i'm gonna use (alot) Simple Green stuff to soak every part (except electrical thingies) I mean soak the snot out of it then power wash it to get 30yrs., of God knows what of build up.
see;
I changed the oil & bought up 7 quarts of Hydro Oil from Cadet to change the trans oil but can't find the drain plug????
Looked in the book (manual) & it does'nt show the drain plug. Am I missing something? Even how to fill it?
Now I consider myself to be quite handy & love to tinker. Did 20yrs., on my ole Craftsman & kept it running. Quite handy with wood projects, just about anything.
Is the fill hole that square thingie on the back plate of the tranny?
Nik,
Old 05-13-2010, 11:28 AM
Once you figure it out. Let me know. I just added hydro oil, threw the hydro dipstick, and took me ForEVER to get 2 quarts down. I'd like to know to. mine has a drain, but it's not at the lowest point, it's just weird man, :P
Thanks
Cody
Old 05-13-2010, 11:43 AM
Danger Danger is offline
To drain them, you're supposed to take off the entire rear cover. Clean up both the rear end and cover, replace the gasket. Bolt the rear end back on. Then fill it with the proper amount.
I can't speak to what the best way to fill them is. I just use the dip stick hole, which does take some time, but I didn't feel it was that bad.
Shawn
Cub Newbie
1811
And always....
Old 05-13-2010, 11:51 AM
jfinney's Avatar
jfinney jfinney is offline
You drain it by taking the back cover off. You refill through the hole in the back of the case (to the level of the plug).
Jason
Old 05-13-2010, 12:04 PM
nikster's Avatar
Thanks, back to the Cub dealership for a new gasket.
My trans does not have a dip stick you can check.
Nik,
Old 05-13-2010, 12:19 PM
Well, that would mean, you use the single bolt in the back of the cover.
it's an interesting way to drain, Very interesting.
Thanks
Cody
Old 05-13-2010, 01:16 PM
The lack of a drain plug forces you to do it right and clean all the gunk out of the inside. To refill, I used a funnel and piece of 5/16" clear tubing. Put the tubing on the end of the funnel, and then shove 8" or so of the tube into the rear. This allows the rear to breathe while you're filling it.
FWIW, the gear drives do have a drain plug.
