Old 07-12-2016, 12:18 PM
cgent cgent is offline
Default Somebody please guide me ... 782D
I've used a red 782D (1980 ish) since around 1990 ... she still works great. I've replaced the deck (rusted out) ... use the snow plow occasionally ... have replaced the rubber donuts in the drive line, most of the electrics, many pulleys, the tires (with terra tires, originals were farm style), recently replaced the electric clutch, rebuilt the starter, replaced the cork gasket between the hydraulic pump and the transaxle last year. As you can see I've had about every bolt & nut off and back on. STILL HAVE A REPEAT PROBLEM ... she burns up an ignition switch every year !!! I've found them as low as $25 recently ... but what would cause the ignition switch to fail so often .... think I have seven dead ones now. After about a years mowing weekly they fail to put out power to the connection for the fuel pump, electric clutch, and lights. Anybody have any clues ???
Old 07-12-2016, 12:26 PM
Are you using a Kubota switch,or an aftermarket one?
Old 07-12-2016, 12:58 PM
Very nice red diesel tractor and great family pics!! Some of the cheaper ones are nothing but junk from afar. Sounds about right, they last long enough and then die out. I'm with Uncle Lewy......are all of your switches from the same brand/company?
NOTE: For your grandchildrens' safety, you should see about putting a belt cover on that deck, though.
Don't know if you have already seen this or not, but perhaps this might help:
http://www.onlycubcadets.net/forum/showthread.php?t=21
Old 07-12-2016, 01:50 PM
Genuine orange & teal box KUBOTA ... recently buying from Messick in Pennsylvania
Old 07-12-2016, 02:37 PM
Terry C's Avatar
Terry C Terry C is offline
That tractor is famous. It's one that comes up if you google 782.
Nice machine!!
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 07-12-2016, 07:31 PM
THANK YOU to whoever resized my HUGE picture !!! Now about the failing ignition key switches ....
Old 07-12-2016, 07:55 PM
What part/section of the switch burns up? Glow plug? "ON"? "Start"? All the above?
More than likely, you have too large a draw either in the glow plug circuit, or the starter circuit. You say you rebuilt the starter, but did you upgrade to the gear reduction? Either way, you need to add a starter relay, and a glow plug relay. This will take all the load off of the ignition switch.
