Old 07-23-2016, 12:18 PM
TexasTom TexasTom is offline
Default 3235 Low Power
3235 bogs down even in low grass.
I replaced deck belt and pto belts, blades, and lubed deck, just to make sure the deck was OK
the rpm before the blades are engaged seems like it might be a little low.
I don't have tools to measure the rpm
the governor looks like its working.
the engine seem to run smooth enough, no smoke
do I really need to check compression to see if the engine is shot ?
could this be somthng simple like fuel filter or ignition ?
what would you all suggest I start checking ??
thanks much
Cub Cadet 2084 w/ 54" deck
Cub Cadet 3235 w/ 54" deck
Cub Cadet 3225 w/ 54" deck
Cub Cadet 2550 w/ 50" deck
Cub Cadet Rear Tine Tiller R65
1969 Case 444 w/3pt
1973 Case 446 w/3pt & rear hyd PTO w/ J70 Tiller
Toolbar w/ 2 disk hiller & potato plow
Brinly single plow
2004 Mahindra 4500
Old 07-23-2016, 12:33 PM
Engine is not likely wore out. Compression check unnecessary.
Yes, could be fuel filter or even a plugged up carb. Could need a tune up or have a plugged air cleaner. Not sure why you would replace belts and blades for a power problem.... that was a waste of time and money.
If you don't have tools to check RPM, either buy them, or just load it up and take it somewhere. You need to be able to check that.
Standard answers: tune it up, flush and clean the carb, fuel tank, replace the fuel filter.
Old 07-23-2016, 12:41 PM
DoubleO7's Avatar
DoubleO7 DoubleO7 is offline
get a hand held no contact digital tach from various sources.
Harbor freight sells one for $40
Many other makers out there.
Old 07-25-2016, 01:12 PM
jdrury jdrury is offline
Default Check the plugs
I had a similar issue on my 3208. turns out one of my plugs wasn't firing. I had been running (remarkably well) on one cylinder. After replacing a coil, I was good to go!
-JOTS
New owner 2016
  • 2001 3208
Old 07-26-2016, 11:11 AM
took the advise and ordered a tiny tach, should arrive this afternoon.
replaced air filter, did not help
will replace fuel filter today
I am waiting to see what the no load rpm is at full throttle and to see how much if any it drops under mower load.
so if the rpm under no load is ok and if rpm stays ok under load even while the mower blades slow to a crawl, then I must have a pto issue correct ? my pto belts even after I just replaced them seem loose to me
will post back after the tach arrives
1969 Case 444 w/3pt
Brinly single plow
2004 Mahindra 4500
Old 07-26-2016, 11:59 AM
FrankF3's Avatar
FrankF3 FrankF3 is offline
I don't know if this applies or not, my father was having a similar problem when snowblowing. The engine would slow right down and snow coming out would barely clear the chute. I found the arm on the governor shaft had loosened up and the arm was moving independently of the shaft. readjusting the governor to specs and tightening the bolt on the arm, restored proper operation and it ran for several more years.
1989 - Cub Cadet 1772
38" Lawn Sweeper #196483
60" Haban Mowing Deck #196374
Old 07-26-2016, 12:02 PM
stlmowerguy stlmowerguy is offline
New to this forum, but not mowers.
If rpm's are down without the blades moving that is where to start troubleshooting first. Tach will help tell you what the rpms are.
If you think it isn't running up to speed the quick and easy test is to pull 1 spark plug wire at a time. If you hear a change then you know that cylinder if firing. If no change, then you have an issue on that cylinder. From there it could be many causes, but at least that would get you going in a direction.
Old 07-27-2016, 10:28 AM
hooked up the tiny tach
full throttle RPM without deck engaged = 3020
full throttle rpm with mower engaged over concrete = 2960
mower engaged with medium grass = rpm drops as low as 1900 and blades pretty much stop spinning
I checked throttle cable and tightened it, raised rpm just slightly to the above numbers
also I pushed on governor lever for a second and rpm will go up to 3800 or more, so why is it only 3020 ? if it can get the fuel to go up to 3800 ?
1969 Case 444 w/3pt
Brinly single plow
2004 Mahindra 4500
Old 07-27-2016, 10:32 AM
Linkage sounds out of adjustment.
Old 07-27-2016, 10:39 AM
This link should get you the Kohler CH service manual.
http://www.kohlerengines.com/onlinec..._690_06_EN.pdf
It will explain how to trouble shoot the engine and how to adjust the governor.
