Can I put a pump on the back side of my hydro on a 149 For rear hydraulics. Thought I seen a post where people installed one but wasn't sure the kind of pumps they installed. Would like to make trailer with dump hydraulics or foe use on other implements.
you dont need another pump, you need to replace the 1 spool valve with a 2 spool valve which will allow you to have either front or rear ports or both.
Does anyone know where the post is about different uses for the shaft out the back side of the hydro?
Where can I get a 2 to replace the 1? |
http://www.onlycubcadets.net/forum/s...ad.php?t=44865
I am also curious as to how 1 would put hydraulic outlets on the BACK of a cub cadet
