Ok guys need some input here. Any of you rebuild the new style haban front casters? OE wheels look to have bushings and sleeves with 1/2 inch bolts going through. Bushings are 1.382 OD and ID is for 3/4 inch shafts. The OD of the sleeves are .750 and ID is for the 1/2 inch bolts.
Just trying to source this stuff locally without paying an arm and a leg but my local bearing store can't get the bushings. I picked up the right ID OD "wheelbarrow" bearings as they call them which looks like it will work but wondering if they're too light duty to hold up against the mighty Haban. Wheel bushings look almost exactly like the O front rim ones but ID is different Thinking about trying to find some pipe to make the sleeves but hoping someone has a source and numbers that have done theirs. I'm re using the wheels btw. image.jpg
I'd bet that the wheel barrow bearings will work just fine if you keep them greased. Here is a link for some tube that should work for bushings.
http://www.metalsdepot.com/catalog_cart_view.php?msg= If your in a rush you could cut the existing bushings in 1/2 and reinstall them with the worn part to the center.
Thanks for the link Sam. I might just do the cut the sleeve in half method temporarily.
