Old 08-31-2016, 06:20 AM
jjv12 jjv12 is offline
Default Frozen shifter on a 127
I serviced trans last year and freed stuck plunger. worked fine. now shifter is frozen. i removed plate in front of seat & trans operates fine still when i manually operate. any clue how to free frozen shift lever/ thanks jim
Old 08-31-2016, 06:46 AM
First, welcome to OCC.......
I would suggest, that you look and examine all the "linkage" components from the Hydro Lever back to the Damper Plate. Sounds like some connection needs to be lubricated and/or replaced.
Old 08-31-2016, 07:06 AM
Thanks for the welcome. my first post here. I checked as much as i could without ripping it apart again. seems to be in handle rod area that runs parallel with steering column. it wont budge, and i oiled everything up good. everything else seems to be free and was fine last year, when i took it apart to free plunger and cleaned out trans.
everything worked fine and there was no linkage problem or play in it. i looked at parts diagram, with no help to what could be frozen. i looked at another hydro recently and lever was frozen as well. it was too rough & i passed on that one. im in nj & machine is upstate ny. heading up there now, & will check replies later. thanks! jim
Old 08-31-2016, 07:21 AM
Attached is a Parts Manual image of the entire Transmission Linkage. Look through it and see if there are areas that you didn't get to.
Old 08-31-2016, 08:13 AM
Thanks. that diagram is exact what i looked at, i was unable to really access the shifter rod and lower washers/sleeve. I flooded it with diesel fuel several times thinking it would get in somewhere, tilted machine on side as well flooding it. the machine was outside over winter & water must have got in somewhere. I thought maybe it had detent balls to hold shift lever in position. let me see how i make out up there. maybe oil worked its way in, i doubt it, but i may get lucky. I just got the machine 1 year ago there, it would only go in reverse. I paid $175 & engine is fine. just a stuck plunger, and trans oil was nasty & waxy. It may never have been changed. It flies now forward. thanks for speedy replies. Very nice site here. Thanks again.
Old 08-31-2016, 08:34 AM
yourshoesareuntied yourshoesareuntied is offline
I had this issue with my 105, I sprayed PB blaster on this portion two times a day for about three or four days, each time I sprayed it I also wiggled the lever back and forth with a medium amount of force (no hammer or tools..just used my hands)..eventually it broke free. ( I'm really new to the IH Cubs, so I don't know how well the 127 linkage compares to the 105.)
IMG_20160820_132128 by yourshoesareuntied, on Flickr
Okie 105 Project Album (Lots of pictures will be added as each section is taken apart, maybe it can help you get yours back together)
https://flic.kr/s/aHskC461kS
