I have a mower deck from my 129 that has been rebuilt with greaseable spindles and I would like to know what other models it fits. The tag on it reads 444 U1111. I intend to sell this as it is in very good shape and I have no need for it.
Russ |
I have the same one on my 169 so my thinking is 129s, 149s, and 169s
What size is it? The 129 could come with a 38 or 42 3 spindle deck or a 44A stamped deck. I think the mule drives are different. The 44A would have the angled pulleys. It would make a difference if someone was buying it and didn't have the proper drive for it. Any of those mowers would also fit a quietline.
Doug Dad's 122 w/42" cast deck, spring assist, lights,weights, rear lift 1250 w/hydraulic lift, lights,weights, spring assist. 50C deck converted to an A with front wheels 44C deck converted to an A with front wheels. QA-36A 42" blade |
I believe it is 44"s. I did not tip it over to measure the blades, just across the deck. Russ |
Depending on how you measured across the deck it may not be a 44A. A 44A measures about 50" across because of the discharge chute. A picture will verify.
No such number. I think it is likely a 44A U1111. Look at that last 4 again. I am certain you will find it's an "A".
That will fit a multitude of machines. More than I want to list. |
Thanks, I will check again. Russ |
pretty sure that mower will fit all the cubs from that era
