Old 09-08-2016, 09:25 AM
rlneyhard rlneyhard is offline
Default 582 Engine swap
Story time... I inherited a 582 that was my grandfathers. (I have a lot of fond memories that include this tractor) He had rebuilt the engine at least one time but possibly more. It ran fine for about a year after I received it but 2 seasons ago the engine slowed and then stopped. I finally got the time to push it into my garage yesterday and began going over the basics.
- Starter is fine (pulled from engine and it runs)
- Pulled the heads and other than a good build-up of carbon they and the cylinder walls look good
- I am unable to turn over the engine
Options:
- Complete rebuild (from what I read this is not worth it)
- Tear down engine in hopes that its an easy fix (not sure if this is an option)
- Swap with used similar engine
Questions that I have:
- Is there anything that I can try to get the engine to turn (without rebuilding)?
- What tractors have the below list of engines that would be best to shop for as a donor?
- Other than craigslist and ebay what are good sites to find engines/tractors locally?
If I do an engine swap here are the easiest engines that I have read about to complete the swap:
- Kohler magnum 20 (m20)
- Kohler magnum 18 (m18)
- Craftsman gt6000 (horizontal shaft)
- Kohler command 18
- Cub 2185, 1864, 1811, 1810, 1806
- Kohler command 25
Thanks in advance for any assistance you can provide.
Old 09-08-2016, 11:42 AM
Gran pa prolly would of liked to see a mag 18 bolt in it, or a series II, and they are around, just not as plentiful as they used to be.
Those engines are as near to original as you can get.
Others here are liking to do conversions to later model overheads V twins.
If it slowed then stopped, it was prolly from lack of oil to the rods on the crank, and it seized, if done @ speed they almost always holed the block with a broken rod.
That is typical of series 1 engines, and they are really not worth rebuilding, and most internal parts are NLA.
they had a lousy oiling system and it cost Kohler a lot of warranty replacements and it's reputation nearly.
Myself, I like the M-18's/or series II, a true opposed engine is smooth and torquey.
Fuel usage and emission requirements killed them.
The M-18's were the last and best of the series.
Old 09-08-2016, 11:56 AM
She shut down at idle. I did check the oil level before starting but like you said the oiling system is not so good on that engine...
I am leaning towards the M18 or M20 if I can find one for a decent price!
Thanks
Old 09-08-2016, 12:49 PM
Is it an IH built unit or CCC?
Old 09-08-2016, 12:53 PM
It's an IH Cub
Old 09-08-2016, 06:18 PM
Not sure but thinking it was mentioned here an M-20 has a 1-1/4" PTO shaft.
and the electric clutches are very expensive and not very popular.
yours is 1-1/8"
I'm sure others will be along to confirm that or not.
Old 09-08-2016, 11:52 AM
Just found a Briggs & Stratton 18hp. - 2 cylinder opposed Lawn Tractor Engine, model # 422437
Has anyone had experience with this engine or know if it is easy to swap?
Thanks
Tags
582, engine, engine swap
