Old 09-19-2016, 05:24 PM
Default Tire tools
I'm thinking about doing my own tire changes instead of "trusting" someone else to do it, but I obviously don't want to break the bank either. I get the concept (I can do bicycle tires in my sleep, and yes I know they aren't the same thing but they are similar) and I think I can do it. I'm looking at a couple of these http://www.harborfreight.com/automot...ron-61603.html just to do the job somewhat affordably since I won't be changing tires like crazy. Anyone have any thoughts, pro or con on them?
Thanks
Old 09-19-2016, 06:01 PM
You need two tire irons and you also need this bead breaker. Price seems to have gone up since I bought mine but they work well on garden tractor tires.
Old 09-19-2016, 06:19 PM
I'm old, I'm Lazy so I take my stuff to the local tire guy. He's stupid cheap and fast. I'm happy, happy.
Old 09-19-2016, 06:55 PM
V30crewcab V30crewcab is offline
I'm lazy too, I bought a used tire machine. way better!
1782, 1862, 1440(sold), 89 1050, 128, 70, some run some don't!
72 scout
IH 404 tractor
Old 09-19-2016, 07:46 PM
ford4150's Avatar
ford4150 ford4150 is offline
Check YouTube for 'breaking tire bead'. Plenty of DIY ideas. Pick the one that seems safest to you and save your money. Get a set of tire irons. HF or eBay.
Old 09-19-2016, 07:53 PM
john hall's Avatar
I bought this from Harbor Freight
http://www.harborfreight.com/Manual-...ger-69686.html
We already had selection of tire irons. So far I have changed all 4 on my Kawasaki Mule, fixed one rear on a 4 wheeler, changed one on a hay baler, and fixed a rear combine tire with it (Don't get excited, it is a SMALL combine--16" flotation tire). I think folks on this site suggested this tool. The only thing I suggest is not to get too aggressive and try to break the bead loose all at once. I've had some to break instantly and others that I had to keep indexing the tire a few times to get it loose. I did have to work on the fit of the part that screws down on the clamp spider (you'll know what I'm talking about if you ever see it in person). It is suggested to bolt it to the floor but I don't have that kind of real estate in the shop so I just manage with it sitting unsecured. I will say you can't use the long bar for coaxing the tires off and on without the tool secured--but it seems to scratch up the rims anyway.
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 09-20-2016, 08:42 AM
My next door neighbor bought two new front tires from Sam's Club. For whatever reason, they couldn't seem to dismount the old ones with their equipment.
I bought the bead breaker from HF only because I never had much luck breaking some of the beads loose from the rims. That's the hard part if you don't have a suitable tool. I didn't think I needed the whole tire changer thing.
When I bought a bead breaker, I think I only gave about $25-$30 for it.
Anybody local here wants about $10 or more to change out a garden tractor tire, or seal the bead or a little less to plug one. I am far too frugal to just give my money away when a tool like this has saved the purchase price many times over in the last 5-10 years.
Old 09-24-2016, 09:06 PM
Bought the tools on Friday. Tire arrived yesterday. With a whole lot of persuasion I got the old tire off (broke the bead with some C clamps) and the new one on. The hardest part was a good tie between breaking the bead and getting the new tire to seat. Knock on wood so far it's holding well and I'm proud to say I did the change myself.
Old 09-24-2016, 10:29 PM
Great job, Daniel!
Old 09-25-2016, 05:17 PM
rwairforce rwairforce is offline
I'm with Sam on this subject.
Yesterday I took a front tire that was leaking to my tire shop and had him put a tube in it. Tube and labor all finished cost me $18.95.
I was at TSC the Friday before and they want $17 for a tube!!! This was an easy decision. Even if the tube was $11 I'll give them the $8 to save me all that effort. FWIW
Randy
Cubs: 71, 72, 127, 149, 1440, 2186 and 1864
John Deere 110 round fender
John Deere 140 H3
Sears: GTV16
