When Liquid filling tires do go tubeless or do you use tubes?
Depends on the quality of the tire and rim seal. If you have a slow leaker you need tubes. If you nave nice new rubber and a very clean bead seat you can do tubeless.
Thanks Sam....
The only way to go is tubes. Cheap insurance.
Hit a hole and shock the tire(s) you could pop the bead.
Project Uncle Dick Cub Cadet 70 http://www.onlycubcadets.net/forum/s...ght=Uncle+Dick |
Never thought of that......I may have to reconsider...
Only problem with filling tubes is if you get a puncture you will have to remove the liquid, fix or replace tube, and refill. With tubeless you can stick a plug in it and be on your way. Also if you go tubeless I would suggest installing metal valve stems. Rim guard has had issues with the water in it breaking down the glue that holds the metal core in the rubber tubeless valve stems. And I would imagine using windshield washer, antifreeze or similar liquids instead would have the same issues.
Collection: 100, 71, 128, 169, 582, 682, (2) 782. 1980 Scout Traveler Diesel. |
Learned the hard way.
