Well it started out with adjusting the brakes so that they would hold when you lock the pedal. Then I thought that while I was working on the new tractor a little that I would go ahead and remove that throttle stop screw so that well, you know, more HP ??? Should have left well enough alone, but I paid the price. Dropped the screw down in the blower housing and could not reach it with a magnet, so not that I had time to do it today, I had to pull the motor out to get to the screw, but what I found was a TON of muck and dirt and a leaky seal. Could not find a seal anywhere local so I had to order it.
See link to album below for pics http://www.onlycubcadets.net/forum/a...p?albumid=1094 Can't say enough about taking the time to blow out those motors periodically. That dirt really builds up bad and can cause a lot of problems that will cost you money and unplanned downtime when you don't want and for something that you could have prevented, to some degree anyway.
Joe 1200 Puller[/U][/B] 1864 2072 with 54 Inch Haban Blade |
I use a leaf blower after every use on my 1864. I also use a tube with the air compressor trying every opening I can find to blow out the cylinders and blower housing. I have removed the engine a few times in the last 20 years. The blower area is still covered in dirt. Removal is again due. Sounds like a winter project.
Just got this tractor so since I have the motor out and the blower housing off, I am going to put some access holes in there to allow me to blow it out occasionally with compressed air. Will also put some holes in the bottom so that everything can blow out.
Will post some pics for the new mod.
Joe
The newer CH's have removable panels on the blower housing, here is a pic.
That is a GREAT solution that came TOO FREAKING late for Kohler!!!!
Did you give them that idea? That is also much better than what I was going to do Sam. Will try to come up with some material and a good reliable way to attach them to the housing without the risk of the screws falling down into no mans land...........again. Some large conduit blank plugs may work as well, I'll have to look and see what sizes I have and how far they would stick inside the housing. Definitely something that should be done to all command motors when you have them out doing the maintenance or any repairs.
Yup, quite the mess. Good work keeping that one going!
http://www.onlycubcadets.net/forum/s...ad.php?t=42646 70, #1 cart. Brinly Cultivator. Some wheel weights . {125, 126, 2072-Sold~regrettably, 2284 60 inch Haban 325 deck., 451 snowblower, 2182-60 inch Haban 374 deck- "Money Pit", 401 Haban 54 inch dozer blade- rebuilt, 1440-down the road, Another 2182 for parts. Another 2284 for parts. 450 blower. 1812-sold, 2072 w/ Haban 374, and a 2182#3 w/ Haban 325}-------> All SOLD |
Works well for me. Take Care, Ike |
Well, Sam got me started on this so, I couldn't stop unless I did something to help prevent this in the future.
Modified the shroud per Sam's picture and added some electrical knockout plugs to the bottom of the shroud so that the stuff can come out as it needs to. I used the foam from an air filter for the cover plates as I didn't want any dirt getting under there, tried just a gasket but that wasn't enough. The foam is glued to the plate just for insurance. Also had the pleasure of replacing the crankshaft seal as well, that was a big reason for the dirt sticking to everything. While I had the driveshaft out, I went ahead and took it apart to clean up that coupling and the 4 steel balls/assembly. Let me tell you now, if you have one of these tractors with that type of driveline, do you and your tractor a favor and take those couplers apart, clean and relube them. Still have a good bit of work to do to get the motor back together and then set it down in the tractor, don't look forward to that tomorrow, that motor is heavy. Getting to old to lift them up out of there anymore. Enjoy the pics you picture junkies................
