Old 10-25-2016, 09:20 AM
Default Stuck k341
Hey guys,
My new 169 has a stuck engine, it had plenty of oil in it, drained it out, no shavings or metal chunks, pulled the head, piston is down about an inch, cylinder looks good, no scoring, intake valve is all the way up and not stuck, exhaust valve is closed, tried turning the engine over with no luck, it's tight! Could the piston really be holding it this tight? If it isn't broken inside I'm thinking pull the rod cap and inspect everything and move rod out of the way and hit the piston down? I'll be pulling it out soon, thanks for any suggestions.
Old 10-25-2016, 09:57 AM
Spray around the piston with pb blaster and let it soak,
Old 10-25-2016, 10:01 AM
I have been with Kroil and MMO, may try some Diesel.
Old 10-25-2016, 07:54 PM
Pulled it apart, disconnected the rod, nothing broken or scored, crank is not moving, looks like it's time to come out and replace the bearings.
Old 10-25-2016, 10:30 PM
you should pull the flywheel off and see it there is something stuck behind it,if you hadn't already done so
Old 10-25-2016, 10:32 PM
bocephus1991's Avatar
I was wondering if it had balance gears in it?
Brian
Old 10-26-2016, 06:59 AM
I had a K series engine this summer with that problem. A guy gave me the whole 1250 tractor because the engine was locked up by a mouse nest and other stuff behind the flywheel.
Like the OP, I pulled the head, then the pan. Then my light bulb came on. A little cleanup and the engine purrs like a new one.
