Just purchased a nos power angle kit for my 1650 42" blade. I noticed that the cylinder is the later style cylinder where mine is the earlier style. The brackets appear to be the same. Will this bolt right on or will I have issues ?
Thanks |
If you don't already have a cylinder, then how do you know yours is the older style??
![]() If the brackets look the same, and that's what bolts on, then why wouldn't it fit? Yes.... it will fit. Bolt it on. I'm assuming that you have a dual stick 1650? |
Are you talking about the ram size? They had the larger and smaller ram. Put up some pics so we can see what you have.
Here are the two cylinders the first is the one I'm replacing because it leaks. the second is the nos they have a slight difference but the mounting hardware appears to be the same. From what I was told, the nos is a CCC part and the other is a IH part and the design was changed slightly but should still work.
Get off the computer, put it on and see how it works. Then report back.
How come, may I inquire, why you didn't fix the old one? NOS = lotamoney.
I may be interested if the price is right on the old one.
small ram has smaller hole in blade end of ram,use the complete large ram kit and no problems about fit.
