Remove the bumper and the blade will mount up the same way the bumper is currently mounted.
I would try to put bars to the back for support.
Somebody made that mount. I'm not saying it won't work but factory ones are braced to the back.
Without a subframe I would caution you to not abuse it to much, It will work just fine but don't go balls out you hit an uneven piece of concrete or something stationary and it could mess up the blade or quick attach. JMHO!
should look and perform well nice find
So I just need to remove the bumper and it should line up correctly? That's what I thought, but there's not much support. AND, does it mount the way I have it shown or does the blade need to be turned the other way?
It mounts the way you have it sitting, that mount you have is something somebody rigged together from a mower deck mule drive. it may bend all to hell the first time you use it for all we know, I remember when you got that and we all told you it wasn't correct, I guess you get to be the guinea pig.
If you put the bolts in, it may hold up ok.
