Old 03-06-2017, 05:51 PM
trickyphish trickyphish is offline
Default 123 Hydro Cub
Picked up an old Cub 123 Hydro yesterday. Is there anything I should do before I put a battery in it and start messing around? It hasn't been started or messed with for many years. Picked it up from a girl cleaning out grandpa's barn. Not sure of the year, but I'm anxious to see what it can do.
Old 03-06-2017, 08:34 PM
john hall's Avatar
Sometimes I first crank stuff that has been sitting a long time just to see how it runs before I change oil, but I don't run it long at all--maybe just a minute or two. Obviously make sure it has enough oil in it. Certainly check for mouse nests that may could cause a fire. If the fuel tank wasn't left nice and dry, I'd rig up an auxiliary tank to see how it ran. Once I hear one run then I start fixing and cleaning up all the issues.
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 03-06-2017, 09:14 PM
Default THX John
Thanks John. I'm not certain but it looks like it was pulled out of the barn and sat outside all winter. The tank has some old gas in it. Think I'll drain it and check the plug before I fire it up. Picked up a battery at Wally World so tomorrow after work I'm going to play around with it. Kind of excited. Always wanted an old sturdy tractor to mess around with. Been through several lower end riders and they never last long. I expect them to do more than they are capable of most likely.
Old 03-06-2017, 09:24 PM
john hall's Avatar
Make sure you have a supply of clean gas going to the carb, or you may get to take the carb apart. If it has been sitting outside (moisture exposure) I'd probably change oil in it, holds about a qt, maybe a little more. Once you get it running and assuming the engine seems solid, then I'd change oil again. Consider the first oil change a $4 engine flush.
2072 w/60" Haban
Old 03-06-2017, 09:37 PM
First off, Welcome to OCC!
Second, I moved this thread to the proper section. The 123 is a IH built Cub.
Third:
I'd do a very loooooong list of things before I try to start any machine that has been sitting who knows how long, that I know nothing about. I wouldn't suggest just throwing a battery in and cranking on it. I'd check everything out first, and drain ALL the fluids and change the hydro filter before I tried starting it. Hell.... I'd pull the head while I had the motor out cleaning the mouse nest out of the blower housing. I'd be shocked beyond belief if it didn't have one after sitting in a barn for years.
Old 03-06-2017, 10:06 PM
Default THX
I guess I better get some oil and a filter before I get too jumpy. Appreciate the insight.
Tags
123, hydro
