Gents, just bought a 1650 QL , bought a new muffler exhaust elbow p/n KH -45-054-04 . in original Kohler box. Threads in head are in perfect shape but the new elbow only gets 3/4 turn in, can go a little more but not pushing it.
Threads on new elbow appear straight and not a pipe thread. I have a piece of brass pipe thread that goes all the way in no problems. whats up here ? what should threads be. Do I have a miss boxed item ? Thanks Carroll |
![]() Part number is correct. The elbow threads into the block, not the head. Get a pipe coupling and see if the new elbow will screw into it. I'd just carry it to a hardware store and try it if you don't have one. My assumption is that the new elbow has a burr on the threads. |
Hey Carroll,
Did you get one of these; |
Already did the hardware store check, anything with a pipe thread will not screw on to the exhaust pipe.
Yes I do have a new locking ring Will recheck threads, I believe they are 11.5 , already chased with a thread cleaner rake. The elbow and threads are painted black, possible need to check again for cleanliness but only goes on 3/4 of a turn ,to me somethings not right, as a brass fitting with pipe threads easily ( snuggly) goes all the way in. Thanks for your response guys Also have a 125 Im restoring too, needed a GT to do the lawn duties as the 125 is all completely torn down for paint removal , will not make it in time for spring...so the 1650 QL came along. |
Good luck with your projects and post up a few pictures when you get a chance.
![]() And hey;
First,welcome to OCC!
![]() Normally a pipe thread is tapered and set to start about 3/4-1 turn by hand, then a pipe wrench turns it home. Possibly they are thinking that the threads are rusty and a bit oversize thus supplying a bit oversize cut thread. Has the new elbow been dropped/distorted? You say it is a genuine kohler part, so you have some choices: You can return it as defective, Or run a bottom pipe tap into the block to insure that it is indeed to size and clean/carbon/rust free to accept the elbow. If all this checks out, run a pipe die on the elbow if needed to get it to size. I'm betting the elbow is a bit big,and there is some foreign material in your block thread as is usually the case. Let us know what you find. I would run a new pipe nipple from the hwd store into your block as a size check, it you do not run it home with a pipe wrench you can return it. |
