Old 03-20-2017, 09:15 AM
Mudhen Mudhen is offline
Default Cub 1045LTX not starting
I replaced the battery Friday. It tried to start one time but instead of the regular sound it was a screech. Now it will not even try. There is no click, no lights on the dash, just silence.
The fall mowing was a bit smokey but I never could tell where it came from. And it did not smoke every time. I last mowed in December and used it in January again. The battery was ok then but I knew it was an older one.
Would appreciate any comments.
I bought it new in 2008 , I think or 2009. I mowed then about 1 1/2 acres but for the last 6 years I mow 2 1/2 acres every 5 - 10 days.
Old 03-20-2017, 09:33 AM
Leadslingingdaddy's Avatar
Normally smoking and screeching are not a good combination... How does the oil look?
have you pulled the plugs to see if you have compression? Will it even turn over?
Is this a Courage engine??
Old 03-20-2017, 02:16 PM
The oil looks clean about the same color as it came out of the jug. And yes it is a Courage. I have not taken it apart yet. Had other things to do. Lawn service came and mowed the lawn so that gives me a little more time.
Old 03-20-2017, 07:14 PM
Unfortunately the Courage engine has a short life expectancy. MTD built the Home Cheapo and TSC Cubs about as cheap as they could just to satisfy a Home Cheapo or TSC price point. People buy them because they think they are getting a real Old School Cub. You'll need to do some diagnostics to find what the problem is. Pull the spark plug and see if it will spin over first.
Old 03-20-2017, 08:02 PM
An LTX1045 really isn't meant to mow "acreage". It's just a lawn tractor.
Is the PTO bearing out? That would cause a screech and the brake on it would prevent the starter from turning the engine over. If it won't crank with the spark plug out, try removing the PTO.
