I've had several people comment on the shine of the 100 I just finished up and have had a few ask which paint I was using. The paint is Case/IH irongard but instead of using there hardener I use Shopline jh6002 high gloss enamel hardener and I mix it 6 parts paint to 1 part hardener with a half part of reducer. Mixing 6 to 1 means that more hardener is used so the paint dries much faster and the Shopline hardener produces a higher shine than the regular hardener. One of the complaints I often hear about the Case/IH paint is how slow it dries but mixing it 6 to 1 the paint was rock hard the next day and I was able to begin assembly. Hope this helps.
Thanks for sharing Tim. It's little tricks like this that turn a good restoration into a great one.
149, 2072, Original, 1772, 1782, #1 cart, Parker 48" sweeper, |
And just where might one find this stuff?
Never heard of it before, but then I am not a painter Thanks! |
Shopline is a PPG brand so you should be able to find it anywhere PPG paint is sold.
Thank you very much for the insight.
What size tip do you use? |
1.3, the 1.4 tip puts the material on a bit heavy for my liking but i don't think a 1.3 is an option for the guys using the harbor freight gun.
Thanks for the tip, I've got some Case backhoe wheels to paint if the Irongard Power Yellow I ordered ever comes in. I picked up some of the Shopline hardener but I was wondering what type of reducer you use? And what kind of recoat times does it give you? Thanks
Flash time between coats is dependent on a few factors like air-flow and temp, when painting with single stage i always recommend you wait until the paint is hand slick before putting on another coat, this will keep you from getting run's and will also prevent die-back which is when the paint lose's it's shine once dry.
Finally got to paint. Ended up with a full part of mid-temp reducer. I like it! Covered real well for a yellow and laid down great. 3 coats and only 1 small run on the backside. Just got done a hour or so ago so we'll see how it dries. The garage is about 70 but the furnace is running a lot to keep it there. That's ok cause it'll be at least next weekend before I mount the tire. I know I'm gonna use this on the next cub I do. Before and after pics with one of my 100's in the background.
