Old 05-30-2017, 05:06 PM
Phil21502 Phil21502 is offline
Default Cub 682 won't start
My 1984 cub cadet 682 has always started right up. This year I just get a click when I turn the key. I got it started a few times with jumping it thinking the battery was dead. Now it won't jump or anything and stuck sitting in the yard. Any ideas on how to to fix this or any ideas? Please help. Could the battery just be that far gone? I even tried jumping it with my truck and nothing
Old 05-30-2017, 06:13 PM
Take apart and clean the battery connections, connections at the solenoid and the ground at the frame. Might not be a bad idea to pull the battery and have it tested also, but it's likely a bad connection.
Old 05-31-2017, 11:28 PM
OP, Your answer to the problem, was posted here...
Good call Jon, guess you didn't need to go through your other post #5.
Old 06-01-2017, 04:40 AM
Originally Posted by Phil21502 View Post
I never knew that a battery could be so far gone that jump starting it wouldn't work.
Yes, it can.
Never assume that an OP actually did what you suggested...... I should have asked before I took the time to write post #5 huh.....
Old 06-01-2017, 03:37 PM
Easy fellas. Sometimes when ur frustrated it's easy to overlook some small things. That whole battery thing still blows my mind.
Old 06-01-2017, 04:03 PM
Rmowl's Avatar
Rmowl Rmowl is offline
At least it was an easy fix and you got your 682 back in action again. More often than not its little fixes we overlook on these things
-Rick
IH 782
IH 126
CCC 1863
Old 06-02-2017, 12:27 AM
That might be an excuse if it wasn't suggested in the first response. Either way, it was an easy fix.
Guess you haven't seen too many failed batteries. Chalk this up for as a learning experience.
Old 05-30-2017, 07:37 PM
Sorry it's a 682. Tonight I have gone over and cleaned all the grounds and checked every connection and everything seems good. I still get just one click noise when turning the key. Is there a way to jump the starter to bypass the starter solenoid? Just trying to narrow it down. If the battery was totally fried would it start while being jumped? On my voltmeter I'm getting 12.6 volts at the battery. What are the syptoms of a bad starter solenoid? Thanks for all the help guys.
Old 05-30-2017, 07:50 PM
twoton twoton is offline
Hey Phil21502, try this;
https://www.youtube.com/watch?v=paw8...-UsNV&index=22
Old 05-31-2017, 01:08 AM
Originally Posted by twoton View Post
That's a fine video is your looking for a bad wire. But at this point, he needs to test some other components, and there are much less time consuming tests he can do to find the issue. Plus, there are only 2 wires that would affect the starter that are on the (+) side. Not too difficult to figure out which one it is without doing a voltage drop test.
Ok... so you still need to do some tests, and confirm what you hear clicking.
First off, the PTO must be in the off position. Are you sure that you aren't hearing the PTO click on and off?? If the PTO is on, the engine will not crank. Check your switch.
Second, confirm it is the solenoid you hear clicking. You can fold the seat up, lock the brake pedal down, put a hand on the solenoid and try starting it. If the solenoid is clicking, you'll feel it.
Third, if it is the solenoid, take a meter and put it on the large output terminal of the solenoid. See if your getting 12V on it while trying to start. If not, check to see if your getting 12V on the small wire running to the solenoid. If your getting 12V on the small wire, but not the big one that runs to the starter, the solenoid is bad.
Yes it could still be a bad battery.
No, I will not tell you how to "jump" across a solenoid. The fact that you asked how to do it means you don't need to know. No reason to burn something up doing it wrong. Actually testing components takes only seconds.
What are the symptoms of a bad starter solenoid?? Ummmmm it clicks and won't start. But that's also the same symptom as a PTO switch in the on position. It's also the same symptom as a bad connection. So... keep testing.
