Old 07-21-2017, 09:17 AM
jd8181 jd8181 is offline
Default Leaves.....what are you using?
I've got my 1864 and love about everything about it, but I do have one little problem. I live in the woods and during the fall I have a TON of leaves. From what I've found they don't make a bagger for it. I've got a pull behind sweeper but it fills up in one pass and if I mulch them then sweep there are still a ton stuck in the grass. So I'm looking for other options. I like he trac vac and cyclones, but they are more than I paid for my mower (I'm keeping my eyes open for a good used one). What are you guys using and what do you think I should get? I've got about 3/4-1 acre.
Old 07-21-2017, 09:20 AM
jimbob200521's Avatar
I have parts of my yard that get COVERED in leafs in the fall. I just go over them several times until they are no longer there, good food for the yard. Also, try to stay ahead of it, don't wait until all the leafs have fallen and then tackle it. I also have mulching blades on my machine so that may help a little bit.
-Ryan
Old 07-21-2017, 11:26 AM
I have a yard similar to the OP. Two yards really.
I started out long ago with a leaf rake, raking in windrows and then burning. They outlawed that. So I got a lawn sweeper/broom. It was useless as it filled up too quick. I tried mulching but never owned any mulching blades. That didn't work out.
Finally, in 1992, the best money I ever spent and it wasn't cheap. I bought an EZ VAC. I've been using it ever since. If your deck is set up right and you don't let the leaves get packed down, it will vacuum the lawn with not a leaf in sight.
EZ VAC is no longer in business but the TRAC VAC looks similar.
Old 07-21-2017, 01:11 PM
JRJP56 JRJP56 is offline
I maintain about 1.5 acres full of leaves in the fall tried many methods but have come down to multching, its more than just the blades, you need the mulch kit for your particular deck. Mine is a metal plate that bolts up under the deck closing off the chute trapping the leaves under the mower for better results. There may be some fine particles when your done but they settle in the lawn or get blown away. I will usually do it a few times a week and works very well when the leaves are dry.
Old 07-21-2017, 01:31 PM
duckpin duckpin is offline
I bought a used Peco vacuum last month for about $350 off Craigslist. We have lots of maple trees as well. I haven't run it yet but hope to soon. They can be pricey, but keep shopping ... a deal can and will turn up.
Oct. 1968 IH CC 105
Broyhill water sprayer
Peco "20" lawn vacuum
No. 2 trailer
And hoping for more!
Old 07-21-2017, 03:30 PM
Wind blows all my leaves away.
But when I lived in town it didn't. Made my own leaf vac cart.
Old 07-21-2017, 07:00 PM
Dart1917 Dart1917 is offline
This is what I use, I currently have 3 set up like this, one at home, one at Mom's and one down at my aunts farm. I like this setup because the trailer follows in the same track as the tractor. With the track vac with the blower on the trailer you have to be real carefull not to hang up when weaving around the trees. Also on the trac vac setup the deck to blower hose has to hang out farther to be able to have enough slack for turning left and bows out when turning right. With the blower mounted on the tractor the hose doesn't have to flex when turning. The blower to trailer hose just twists a little when you turn.
Old 07-21-2017, 09:32 PM
farmall fred's Avatar
farmall fred farmall fred is offline
I use a GT 46 deck and a bagger attachment from a cyclops series on my 782 to mulch and bag leaves. As long as the leaves are dry it works very well. I have thought about adding a deck powered blower to the 60 inch deck on my 2882 custom super but for now the bagger attachment works well. Bagging leaves is the only time I use the GT 46 deck as it tends to clump grass rather than spread it. Rest of the time I run a 50C on the 782.
Tom
Old 07-21-2017, 09:33 PM
I mow 'em and blow 'em around or use my push mower and mulch them.
Old 07-21-2017, 10:44 PM
Green stripe wide frame's Avatar
Green stripe wide frame Green stripe wide frame is offline
This is depressing, we are already talking about leaves. GROSS. Don't even mention the 4 letter S word yet.
102 soon to be tiller machine
108 mower
73 plow machine
169 soon to be mower
122x2 now parts machines
Parts 129
149 parts
61 "O"
104 job to be determined
