Old 08-01-2017, 10:04 PM
Default Lawn mower carb help on a Corvette forum
Sometimes you got to sit back and wonder what they were smoking/drinking/banging their head against.
Originally Posted by poster 1
If there are issues with the passageways, he's going to have to readjust anyway. Most times, there is a standard setting that can be found online and minor adjustments can be made from there.
Originally Posted by poster 2
Correct. The usual rule is 1.5-2 turns open to get it to crank, then adjust to fine tune after carb is fully warmed up.
And a "turn" is not a 360deg rotation. More like 180deg
Ohhhh, my head hurts
I'm staying out of this one
Old 08-01-2017, 11:50 PM
cubby102's Avatar
cubby102 cubby102 is offline
Most likely a predominant efi vette page? Ain't no way In heck they are gonna be able to tune a q-jet :/
Old 08-02-2017, 08:42 PM
The guy with the problem had a newer Corvette, the guy offering help is a street rodder.
What I found most humorous was that a turn wasn't really a turn.
Old 08-02-2017, 09:21 PM
mortten mortten is offline
I'll bet it will crank with the screws fully closed. Probably won't run though.
Doug
QA-36A
42" blade
Old 08-02-2017, 09:39 PM
Luckily he didn't have to get into the carb. Fresh gas "allowed" it to run.
Old 08-02-2017, 09:45 PM
Internet is full of wannabe mechanics. Nothing surprises me anymore. Still gives me a headache.... but doesn’t surprise me.
Shrewcub's Avatar
Shrewcub Shrewcub is offline
Same here, but I understand. When I tune a carb, I count in half-turns. If I count to 5, it's 2.5 turns tho. Clear as mud right?
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
But what he implied was the 2-1/2 turns YOU end up with would be 1-1/4 for him
