Old 09-17-2017, 08:49 AM
tmx43 tmx43 is offline
Default Changing valve guide
I tore down a k301 and it seems to have play on the old valve stem. do I need a special tool to remove and replace them. I do know the new ones will need reamed to size. thank you
Old 09-17-2017, 08:50 AM
I have changed them before. I just took a Hammer and a Punch and drove them out. You could also do it with a Press.
Old 09-17-2017, 11:05 AM
It's an ai cooled engine. The valve guide aren't real tight. You can replace them, as they can wear, but I think you'll find the new ones "loose" also. I've not ever needed to reem new ones. Best way to know if they are shot, is to measure them. If you don't have a valve bore guide, you probably shouldn't be making decisions about whether they are wore out. Have the machine shop that bored/bores the block check them.
Old 09-18-2017, 11:33 AM
thank you for the info. I didn't measure them but there not the same size . the exhaust is somewhat larger than intake. most machine shops in my area have nothing to do with small engines. out of the 5 or six I called with in a two hour drive only one agreed to look at the block to see if he could bore it. one shop said they would recommend buying a new engine instead of rebuilding a small engine.one shop said the quit crank grinding because new cranks for 350s could be bought so cheap.
Old 09-18-2017, 01:10 PM
Are you comparing new valves, or old ones? Exhaust guides will be more loose. Exhaust gets hotter, expands more.
Old 09-18-2017, 05:57 PM
yes the exhaust valve was more loose. i haven't ordered my valves yet but ill compare it when i get them . the exhaust valve was egg shaped bad.
