The following (in quotes) is an ad. Based on the information given -- WHAT'S IT WORTH?
"Cub Cadet 2084 SGT for sale:.......- 2084 cub cadet. Low hours CH18 Kohler command engine. New OEM ignition coils, New OEM carburetor, New OEM mechanical fuel pump upgrade, new breather cover and gasket, new battery, new starter, new PTO belt. Tractor comes with oil pressure gauge and tiny tach. Tractor runs great and has been completely serviced. Nice 50" mower with new deck wheels with gator blades. All the plastic is in good shape. Everything works as it should." Also, would attachments (deck and snowblower) from a 1882 easily interchangeable? Thanks |
First the 2084 was only made for one year. This 2084 has been repowered as the 2084 came with a ch20s engine. It also has been modified with the addition of gauges. The mower deck if it is a 50 inch deck will not be wide enough to cut wider than the rear wheels. If I were to check this one out I would first check to see if the head gaskets are not leaking, the rear bolts are all there and are tight. This may be a real gem or not. With all the replacement items noted it may be someone putting lipstick on a pig. As to price I don't know what it may be worth without a thorough face to machine inspection. Also remember it is no longer a true 2084.
With my son, EricR Super 2084 with 54" mower, 451 blower. 2086 with 3 pt hitch, 54 inch deck, 551 blower, 54 in brinly blade. A 4 digit original w deck. A 70 with deck. 2 102s both with 42 in decks, one with creeper, 1 36 inch IH snow thrower CW36, 1 42 inch IH blade. 149 with mower. 2072 w 3 pt hitch, Johnny bucket, 60 in mower, 451 blower. Jacobson GT 10 with mower. DR Lawn vac tow behind,Home made lawn roller. Brinly cart, 2 off brand carts and 1 home made cart. |
Pictures are needed on this one. There are to many things that could go wrong. The mechanical fuel pump, to me, sounds like he may have put a magnum in.
1572, 1864 x2, 1810 x2, 1863 & GT1554(Dad's Ole Mowers), 1811,782D, 1872 x2, 782DT(Sold), 3235, 1860, 1772 with 3-point and Turbo. |
The ad has only a single pic - no detail style pics -- I'll contact the seller via the ad to see if he'll send me more.
Pics..........
I see it has a cast iron tranny, was it upgraded with the original parts from the aluminum trans that was in the 2084?
Tires in the rear look shorter.
The pictures are correct for the 2084. The hydro was painted black from factory. It came with the Kohller ch 20 like it shows
