Hi there: totally new here , been lurking and decided to pull the trigger on a 1989 1811 in pretty good condition. The engine was rebuilt and has about 30 hrs on it. I needed something for just snow to clear a 180 ft driveway here in New England and this tractor seemed to fit the bill, it came with weights chains and the 450 blower. My other option was to fit a snow thrower on the front of my Craftsman lawn tractor. - I soon talked myself out of that!. Anyhow, I got the tractor home yesterday and was a little disappointed to find a very small puddle of tranny fluid on the garage floor after running it for a bit and operating the hydraulic lift etc. I wanted to find out where it was coming from so I took off all the covers and after cleaning everything and running again it's clear it's coming from the drive shaft entering the pump. After it's stopped it no longer leaks.
So my questions are ; is this normal and a big deal on a 30 year old tractor and should I fix it.? Or just leave it , let it drip and keep the fluid topped up.? Is there anything that could cause the leak like over filling the tranny or too much pressure build up etc.? And last but not least how do I get the drive shaft out of the pump to replace the seal if I decide to tackle it? I don't think I need to remove the transmission and can maybe decouple the shaft and get at it that way? I have attached some pics of the tractor and also the drive shaft leak point into the pump. Any assistance or advice would be much appreciated , I'm totally new to tractors of this vintage but I can tell straight away by driving it that this thing blows the socks off my 24 hp Craftsman ..way more torque !! And it's built like a tank. They certainly don't build them like this any more. Role on snow here in New England Cheers Tom |
Welcome, I'm also new here. A friend donated his abandoned 1811 to me since I like to tinker. It was parked in a barn 11 years ago. I wanted a real tractor to push snow and I think this will do it. I'm just looking for some chains and a blade and I'll be ready IF we get any snow this year.
I've had to repair quite a few things on mine to get it running well but this 1811 was built to be repaired unlike my troy bilt. I posted several pictures of the issues I've had with it over the last couple weeks. Just search for "barn find". This weekend I'll install new front wheel bearings and try to to tighten up the sloppy front axle. And don't mind the trolls. They're harmless. Look out.... here comes another one.... just pretend you don't see him. Rob |
very nice, welcome to the forum
64 Cub Cadet 100 Also have quite a few Non Cub Cadets in the Shed ![]() |
Congrats on the 1811. They are considered one of the best Cub's. As for the trans leak, this far into the season I would just live with the leak and keep the fluid topped off. It never fails that you will no sooner get it torn apart and you will need it.
Nice first Cub! Welcome to the forum!
Stanton 1980 IH 782, Kohler M18 IH #1 Cart, original IH 42" Blade, modified to 50" and hydraulic 2015 XT2, Kawasaki 23 HP |
![]() Like stated, the 1811 is one of the best GT's Cub Cadet ever made. Second only to a Super Garden tractor, or maybe an 1864 and that's only because it (1811) doesn't have power steering. (And you will wish it did with that blower on it! ![]() I have ran that combo for years. Great set up. You are going to wish you had a cab after blowing a lot of snow with it though. ![]() You got a really nice machine. Looks to be in good shape! The blower looks as if it hasn't ever really been used. As far as the leak goes.... It wouldn't take long to pull the driveshaft and replace the seal. Is it a common issue? Well..... it's a 30 year old machine. I've replaced the seal in mine at least once, maybe twice in the 15 or so years I've had it. There are some other places that are more common to leak, such as the trunion seals, cork gasket and relief valves. I'd probably take an afternoon and fix it. Taking the shaft out is not terribly easy on that tractor. Either the rear or the engine has to be unbolted and slid back a bit to get the shaft out. For what you have to fix, I'd probably loosen the engine plate. No reason to take the rear loose unless you need to. As a note: I'd be changing at least the filter on the hydro. I can see it in the pic. They haven't used that logo is quite some time. May even be the original filter. Makes me wonder if the oil in the rear has ever been changed. I'd change both oil and filter. A Wix 1410 or Napa 51410 is the filter you need. |
Congrats on the nice 1811 Tom and welcome!
The 1811 is an awesome GT. I sold one this summer to a friend. I miss it. The steering is hard to turn with a blower on the front if the grease zerks haven't been regularly pumped with grease. The steering gear can take a lot of grease. I put some high performance Teflon lube down the steering wheel shaft and in the tie rod ends and I think that helps a lot. I also use a spinner on the wheel. It looks as though the auger is a little bent on the snow blower. I use a large Crescent wrench, or two, to straighten my auger if it needs it. Have fun this winter blowing snow! PeterJ
1863 48" deck, 3pt 1864 x 2, 54" deck, power bagger, 48” deck 1811 44" deck 1210 44"deck IH trip plow QA42-A, 451 x 2, 551 42" Earthcavator Driveway Drag ![]() USAF Shepherd's Chapel |
Nice looking 1811 and blower! Those 450 blowers are getting hard to find in good original condition. Glad you're enjoying it so far. And yes, get those auto-release valves pulled and rebuilt when there's a break in the weather. They can let go all at once and make a big mess and ruin all your fun.
Tom 105, 149 w/44A, #2 & #4 carts 782 CCC Red w/44C 1512 Smoker w/50C, 450 Blower 2072 w/60" Haban IH/Lawnboy 3322 Pusher, Scag TT 61" JD 455, X495, Kubota 2150, Gravely 450, 812 |
Well the last couple days have been a good work out for my 1811 with 450 blower. We got just over a foot with some nice 4-5 ft drifts from a nice Noreaster . Very impressed how she handled it.
I definitely need more weight on the back of the tractor for the bottom of my driveway though . The grade is pretty steep and I slip even in slush pulling back up . Finding the right speed and leaning back over the back wheels with a nice run up seems to be best. I think a few suitcase weights will fix it and if it doesn't will think about filling the tyres. I did notice the V- belt the previous owner installed on the 450 and had written in pen under the hood was 5/8 x 82" ...the part number states an 84" ...will the 82" be too tight and be likely to break on me . ? - seems to be working o.k... Thanks a lot again guys! Tom |
